S-10 & Blazer 1982-2005
'88 S-10 starter problem
Old Sep 10, 2006 | 6:45 PM
TreeFrog's Avatar
Default '88 S-10 starter problem
I've got an 88 s-10, and a problem. I got in it last week, turned the key...nada. No clicks, no cranks, nothing. Lights, horn, etc. work, so I don't think it's a battery issue.
Just got finished replacing the starter. The new starter worked in the parts shop (I had them hook it up to make sure). So, new starter, got in, turned the key...nada.
After a few choice words, I pushed it back in the driveway, put up my tools, and found this forum.
Can someone PLEASE suggest where I should look for a problem now?
Thanks
Frog
Old Sep 11, 2006 | 2:34 AM
kcb37's Avatar
Default RE: '88 S-10 starter problem
Make sure your battery, and starter wires are connected tightly, and that they are all connected. If that dosen't do anything find the starter relay and check that. If it is not that it may be your ignition switch.
Old Sep 11, 2006 | 10:56 AM
TreeFrog's Avatar
The relay is the solinoid, right? That's new, too (it was attached to the starter).
If the relay's not the same as the solinoid, please let me know.
If it is, then I reckon the switch is the problem...
Old Sep 11, 2006 | 11:28 AM
kcb37's Avatar
The relay is not the same and should be somewhere on the firewall or the fender. I think it should be on the drivers side. When I say ignition switch I don't mean where the key goes in. I should have said starter switch. In the steering colum the key pushes a rod down when you turn it. At start the rod hits the starter switch. It will be somewhere toward the mid to bottom section of the steering colum.
bavant
Jan 16, 2012 2:12 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
dkirby9152@aol.
Dec 15, 2005 3:31 AM
Gill
Jun 15, 2005 7:53 PM
