S-10 & Blazer 1982-2005
91 S10 wont start
Old Nov 18, 2013 | 2:28 PM
wsanders's Avatar
Default 91 S10 wont start
Im having some problems with my 91 s10 and was hoping for some helpful tips. Ive had it since february and havent really had any problems with it until now. My wife went to drive it on saturday and after she put it in drive it died and hasnt started since. It looked like it wasnt getting enough fuel so I changed the fuel filter. That didnt help so i changed the ignition control module, that seems to be a common answer on other forums. That didnt work either. The fuel pumps only a yr or so old and i can hear it kick on when i turn the key. Im not real sure what else it could be and would appreciate any advice. Its a 91 with a 4.3 litre 2 whl drive. It does have 280,000 miles but its been very well taken care of. Thanks
Old Nov 19, 2013 | 11:31 AM
Check the fuel pressure. If the fuel pump was replaced with a cheap aftermarket pump then it could be bad. The cheap ones don't tend to last very long. You can still hear it kick on, but is it getting to the necessary pressure?
Old Dec 4, 2013 | 8:12 PM
tim_cleav's Avatar
Cool
so anytime you think you have an ignition module problem pour a little gas down the intake, & turn it over, if the engine fires it is NOT the ignition module & is probably the fuel pump, fuel filter or worse computer issure - however if it does not fire then it is most likley the ignition module or computer to blame.
also have you looked at fuses/relays?
sounds to me like it is the fuel pump, the blazers have the tendancy of the pumps just to go without warning one day. just kapoot and their done.
Old Dec 9, 2013 | 10:31 PM
Mallow's Avatar
I used to have a truck that would do this. It would fire but never start and we replaced just about everything. The only way we got it started was to assume there was a short somewhere between the fuel pump and the ignition. Sure enough there was. We ran the fuel pump to the running light switch and she runs like she did before! Hope you get it goin!! Good luck to you.
Old Jan 18, 2014 | 5:32 AM
MrJason's Avatar
Try checking if any of the fuses burned out
Old Jan 30, 2014 | 3:54 PM
tim_cleav's Avatar
okay so is it firing when you turn it over? or is it just dead turning? because if it is firing/and buffing when it turns over then it may have something to do with the distriputor or spark plug/coil wires...
sleepingciv
Jul 25, 2020 1:03 PM
S10guy
Jul 23, 2013 4:10 AM
Punisher327
Jun 26, 2011 7:56 PM
dj alacran
May 24, 2011 12:05 PM
holyearth
Nov 10, 2009 7:09 AM
