S-10 & Blazer 1982-2005
97 S-10 4.3L V6 Bucking on acceleration after ticking event.
Old Apr 11, 2011 | 3:37 PM
Dave124's Avatar
Default 97 S-10 4.3L V6 Bucking on acceleration after ticking event.
Greetings.
After getting gas yesterday, I got onto the freeway and accelerated to approx 70MPH. I heard a consistent "Tick, Tick, Tick" just a bit louder than a turn signal, and about a second apart, and sounded like it was coming from the dashboard. After approximately 30 ticks, the RPMs dropped and I had little to no power. The truck bucked violently. The engine gave me enough intermittent power to exit the freeway. I parked the truck and there is no longer a ticking sound. The ticks went away once the RPMs dropped and I notice there was a problem. At idle, the truck runs almost normal. The second I add gas, the engine bucks and the RPMs run up and down, mainly down. I think getting the gas was just coincidence. The truck has been poorly maintained. Anyone have a guess on what this could be? I have read several posts on this forum and I haven't seen anyone write about the ticking sound I heard prior to the event.
Update: After having it towed home, I was able to start it several times but not accelerate because the RPMs would drop. Today it won't even turn over to start.
Thanks!!
Old Apr 25, 2011 | 3:17 AM
Dave124's Avatar
Thanks for all the replies... NOT.
Just in case someone else has this problem...
The ticking sound was my distributor cap going bad. Once the distributor cap was removed, I could see an unusual burn mark through the plastic. I replaced the rotor and cap and now the S-10 works again.
SpeedTrap47
Aug 8, 2010 12:46 AM
Chadular
Chevelle & El Camino
Mar 29, 2010 12:58 PM
hphammer
Astro
Jan 25, 2008 8:44 PM
carguy27
Dec 19, 2006 1:21 AM
chrisrud15
Oct 25, 2006 2:25 AM
