S-10 & Blazer 1982-2005
98 s10 applying brake engine starts
Old Jan 28, 2015 | 1:02 PM
ckpilotcars's Avatar
Default 98 s10 applying brake engine starts
So I'm new to this group I own 9 s10 and blazer I have a 98 2.2 auto the ignition was stuck yesterday when you turn it over it would start but stay turning over unless shutting it off so of course I had to turn key to sec click pull starter relay put it back in start the s10 then pull relay so I went out to get a new ignition switch the eltrical side went this morning to fix problem and when taking off the first bottom panel where the emergency brake is I lay it down bump the brake paddle with no key in also in park and the truck fired up so I took out the starter relay and when I hit the brakes the fuel pump is in ganged is this the ignition switch I'm stump
Last edited by ckpilotcars; Jan 28, 2015 at 1:04 PM. Reason: spell check made me miss spell
er2cc
Nov 1, 2014 8:32 AM
dcarrer0
Aug 2, 2012 10:04 PM
Auto Angel
Aug 5, 2010 3:12 PM
BigDrew
Jul 31, 2008 9:13 PM
