S-10 & Blazer 1982-2005
Bad Vibes from front passenger!
Old Oct 15, 2009 | 8:47 PM
Gaber99's Avatar
Default Bad Vibes from front passenger!
'99 Blazer 4x4 2dr
I'm almost positive it's my bearing/hup assembly on my front passenger side that sounds like I stuck a steel baseball card in the spoke of my bike. It's also vibrating the car, much higher frequency than an unbalanced tire. Anybody want to confirm before i throw down for the new part!?
This is my first project. Next is flushing the heater core, then finding out why it loves to go into 4 wheel drive but not out!
Thanks!
Old Oct 17, 2009 | 10:10 AM
Siliconasp's Avatar
Originally Posted by Gaber99
'99 Blazer 4x4 2dr
Thanks!
You stated 99 4X4 2DR... then the next line stated Bearing/HUB Assembly
confusing to me, but having had both verison of the Blazer, I understand the different.
1. It would be the Axle bearing on a 4x4 (New bearing and packing $50 to $100 if you do it yourself.
2. It would be the HUB Assemble on a RWD. (about $250 to $300 for replacement part)
I would also recommend you check your engine mount on that side for wear and failure.
But it does sound like the bearing is your issue. I had a 2001 Blazer blow the front bear in the HUB and it made the same sound. Replaced the whole hub with just a few hand tools in the parking loot of my apartments, took about 1 hour.
Bearpaafishin
Aug 11, 2014 7:34 AM
Chev_Hoe
Jan 14, 2014 9:41 PM
bavant
Jan 16, 2012 2:12 PM
LatitudeDancer
Jun 3, 2011 1:06 PM
davemec
Sep 25, 2006 11:52 AM
