S-10 & Blazer 1982-2005
Brake dust shield removal
Old Jul 11, 2010 | 2:38 AM
svebbe's Avatar
Default Brake dust shield removal
New here...with my first Chevy ever. It´s a 1999 S10 LS 4wd. I´m in the process of removing brake calipers, rotors and brake dust shields on the rear and front. All vent fine until i needed to remove brake dust shield. How do you do it? Do i need to remove the axel to do it? Seems to be alot of work just to get the brake dust shield out.
I´ve sent for a workshop manual (DVD), but i thought i post my question here while waiting for it...
Old Jul 11, 2010 | 3:21 PM
Bill's Dad's Avatar
I had to remove the hubs to replace my front shields...
Old Jul 15, 2010 | 9:35 AM
frickenbored's Avatar
yup, you gotta remove the hubs, three bolts from the backside.
Old Jul 15, 2010 | 11:34 AM
svebbe's Avatar
Ok, thanks both of you!
Old Jul 17, 2010 | 12:36 PM
svebbe's Avatar
....haven´t got the manual yet...but it looks like below. There are no more bolts to remove as i see it...when i spin the hub on each side both hubs move....do i have to yank each hub out with force to get them loose? I can´t damage anything that way? Hope you can see what i mean on the pics....
Old Jul 17, 2010 | 7:00 PM
Bill's Dad's Avatar
looks like the rear dust shields you were speaking of...we thought you meant the front. To remove those(rear axles) you'll need to remove the rear cover, then you'll see a 5/16 hex head/bolt on side of carrier-remove with care, it's a locking bolt that holds in the 7/8" or so pin, slide out, push axles in to gain access and to remove C-clips then you can slide axle shafts out.
Old Jul 18, 2010 | 3:28 AM
svebbe's Avatar
Yes...it´s the rear dustshields i´m talking about. Forgot to mention that. Sorry. When you say remove rear cover....which cover do you mean by that? What´s the name of the cover (so i can google for pics of it)?
Thanks in advance....
Old Jul 20, 2010 | 4:22 AM
svebbe's Avatar
Got the manual...and now i understand what you meant...
I need to remove Rear Axle Housing cover to unveal the c-clip....and after that i can remove the axel all the way out.
Old Jul 23, 2010 | 1:31 PM
svebbe's Avatar
....or i could just saw them just enough to get them over the axel maybe
Old Jan 28, 2011 | 9:21 PM
rbrace's Avatar
i thought of sawing mine
jwiley7
Camaro
Feb 7, 2014 1:06 PM
wwotr
Apr 21, 2011 1:08 AM
exuL1B47
Dec 3, 2009 6:11 PM
Bizarre11
Jan 20, 2008 3:42 PM
jffgin
Oct 11, 2007 7:46 PM
