S-10 & Blazer 1982-2005
Brake lights not working
Old Mar 17, 2020 | 3:15 PM
jtinker101's Avatar
Default Brake lights not working
I have a 2000 S10 3 door - 2.2L - 5 Speed
I went to get it inspected today and the brake lights didnt work
the turn signals work fine, but the emergency flashers dont work
brake liight fuse seeds to be good (power going through it)
anyone have this problem before? could it just be the brake light switch? its a little thin white box with a pin attached to the brake lever
thanks
JT
Old Mar 17, 2020 | 4:14 PM
did you check the brake bulbs?
Old Mar 17, 2020 | 5:43 PM
jtinker101's Avatar
no havent checked, I thought the S10 only had two lights in the tail light 1 backup light and 1 turn signal / stop light
if they have three I will check it out and see if thats it
thank
Old Mar 17, 2020 | 5:57 PM
to be honest, I can't remember the last time I needed to change a brake bulb.
If they were the same, then you'd only have one brake light if you were using the signal at the same time?
Could be the brake switch too.
Old Mar 17, 2020 | 6:36 PM
jtinker101's Avatar
will be checking the stitch.. I can hear the brake switch click when pushing the pedel... but still could be bad
Old Mar 30, 2020 | 4:46 PM
hogbiker's Avatar
Be sure to return and post what ended up being the cause..Alwyas like to hear sucessful endings
Old Mar 30, 2020 | 9:40 PM
jtinker101's Avatar
with the turn signals working, but not the brake lights or hazard lights... the only thing I could think of was the brake light switch
on the 2000 S10 it's up under the dash attached to the brake pedal arm.... not easy to get to...
ordered a new one and after swearing at it a few times got it out and the took care of the problem...
Old Mar 31, 2020 | 2:56 AM
hogbiker's Avatar
Good DEAL...thread solved....yeah...most brakelite switches in any vehicle are a PITA to replace... I had a dickens of a time w/the one on my Chrysler 300M getting the new switch mounted properly so that the plunger activated the brakelites neither on too soon or too late
PatrykKoul
Apr 26, 2023 9:14 AM
ChevyIshi
1988 - 1998 (GMT400)
Mar 5, 2019 8:38 PM
calemleyjr
Uplander
Feb 16, 2018 7:37 PM
cooktruck
Aug 5, 2016 9:26 AM
alias317
Mar 26, 2013 1:38 AM
