S-10 & Blazer 1982-2005
Brake problem
Old Feb 12, 2014 | 1:38 PM
Green_Blazer's Avatar
Default Brake problem
I took my 2001 blazer in to replace the upper and lower ball joints, pitman arm, and to have the tires realligned. As soon as I left the shop my brakes started acting up. The ABS system kicks on every time I brake. This was not happening before I had the work done, but the shop denies the work they did has anything to do with it. They say it's because the brake cylinder is leaking, though it looks to have sufficient brake fluid. Are they wrong?
Old Feb 12, 2014 | 3:39 PM
Look at the wires from the ABS sensor on each wheel to see if they were damaged in any way.
Old Feb 12, 2014 | 11:15 PM
Default Thank you
I am going to take it to the dealer tomorrow. I will mention your advice. I wouldn't really know what to look for if I did it myself. If they do find damage, do you think I can get the shop that did the initial work to fix it for me, free of charge? I'm having a hard time believing they had nothing to do with this new issue.
Old Feb 13, 2014 | 11:04 AM
They will probably say that they didn't do it even if the sensors are damaged. They will say that the damage occurred after you picked up the truck.
Slobby Baymon
Nov 12, 2013 11:52 PM
cmcbride
Avalanche
Aug 8, 2012 3:12 PM
Thad W. Posey
Jun 15, 2012 9:21 AM
tom5170
Mar 19, 2010 11:57 PM
