S-10 & Blazer 1982-2005
cam shaft sensor
Old Aug 23, 2009 | 5:33 PM
pgsoap's Avatar
Default cam shaft sensor
was replacing sensor when i went to take it out the guts was the only thing that came out.casing is still in the engine. how is the best way to remove it? i tried using an ease out but when it tightens up the casing will not move. i am assuming it is siezed in the block. sensor is located on right side of engine by the coil packs.not much room to work in.
Old Aug 23, 2009 | 10:11 PM
MDTAHOE's Avatar
Professional Mechanic
What year is your truck? What size is the engine? We need all your information to proper;y help you.
Old Aug 24, 2009 | 3:32 PM
pgsoap's Avatar
sorry it's a 96 2.2 liter
Old Jan 15, 2011 | 11:02 AM
punshka's Avatar
We have a 95 Blazer with a 4.3 that has a bad main bearing. With having a bad main bearing, would this cause the crankshaft sensor to make the car cut off while driving? Please let me know! Thanks.
edick065
Mar 17, 2014 6:33 PM
Redneck24v
Jun 17, 2011 1:14 PM
muddin61483
Jun 11, 2010 10:32 PM
rich_ncal
Nov 23, 2008 9:51 AM
chamberslj
Jun 7, 2008 5:23 PM
