cam shaft sensor
was replacing sensor when i went to take it out the guts was the only thing that came out.casing is still in the engine. how is the best way to remove it? i tried using an ease out but when it tightens up the casing will not move. i am assuming it is siezed in the block. sensor is located on right side of engine by the coil packs.not much room to work in.
edick065
Mar 17, 2014 6:33 PM
muddin61483
Jun 11, 2010 10:32 PM
