S-10 & Blazer 1982-2005
Chasing a bad connection
Old Oct 17, 2023 | 11:13 AM
Jadgsxr's Avatar
Default Chasing a bad connection
I'm a new member here but, not to forums. Usually through a simple search you can find someone else who has experienced the same problem and I think it's awesome that we can learn from each other.
I've read a lot over the last few days and it helped me narrow it down. I'm working on a 2001 Jimmy 4.3. After correcting many other issues I'm left with a fuse that instantly blows. I'm hoping someone can tell me what circuit Ign C entails. It's a 20a in the box under the hood. When I put a new fuse in, right as it snaps, the front marker light blinks with the snap.
Any help or advice would be greatly appreciated !
Old Oct 17, 2023 | 2:31 PM
IGN C circuit is responsible for A LOT of things, my friend.
It runs through your ignition switch, and then to your cluster, as well as back through the CRANK fuse before it branches out.
I suggest you find yourself a Haynes manual or something with electrical schematics.
marker lights should be a separate circuit though, so maybe you have some crossed wires somewhere.
ill4na8na2
Apr 7, 2024 6:50 PM
trund
Sep 18, 2020 9:25 AM
Chevyman06
Nov 14, 2015 4:45 PM
Dioak
Feb 17, 2014 12:24 AM
BigHeavyChevy
Apr 26, 2010 8:45 PM
