S-10 & Blazer 1982-2005
Chevy S10 (4.3L) wont drive past 25-30mph. Just revs at that point.
Old Nov 29, 2015 | 2:03 PM
investbo's Avatar
Default Chevy S10 (4.3L) wont drive past 25-30mph. Just revs at that point.
My 2000, Chevy S10 (4x4, 4.3L) will not drive past 25-30mph. Once it hits that speed range, it just revs-up. Any ideas or thoughts?
Old Nov 30, 2015 | 6:17 AM
May be the transmission. Try driving it with the selector in 3 and then 4 and see if it still happens.
Old Oct 3, 2019 | 9:04 PM
shatzley's Avatar
Smile
check your catalytic converter mine did about the same thing, revved up but didn't get pass a certain speed.
Old Oct 5, 2019 | 12:33 PM
Irish_alley's Avatar
I'm here for the party
a way to check the catalytic converter is to remove the upstream O2 sensor. this should let it "breath" a little more and might clear up the issue
Old Feb 6, 2020 | 11:37 AM
Liz Kelly's Avatar
Default Won't drive past 25-30
You need to drop the transmission pan and change the filter and clean it out. I had a problem with this for awhile. Check for metel shavings in the filter and the fluid. Those metel flakes are plug it up.
Old Feb 6, 2020 | 11:41 AM
Liz Kelly's Avatar
Check to see if your gears are grinding together. Mine was the motor mount broke which caused alot of shaking of the transmission.
Anita Godfrey
Aug 2, 2018 2:10 PM
vetsir
May 4, 2010 11:44 AM
bikes91
Jan 21, 2008 4:35 PM
Outcastz89
Nov 30, 2007 12:10 AM
dragonrpc
Jan 8, 2007 3:06 PM
