S-10 & Blazer 1982-2005
Cylinder Heads
Old Jan 29, 2019 | 8:15 AM
Lucn920's Avatar
Default Cylinder Heads
I recently bought a 99 Blazer that was leaking coolant into one of the cylinders so I opened up the engine and one of the heads is cracked. The problem is there was some shady mechanics going on and it has two different heads with different style rockers. I searched forever and couldnt find which one my truck is actually supposed to have on it. Does anyone know the difference between heads with the casting numbers 113 and 114? Or if I need screw in rocker studs or bolt down rockers? Thanks in advance.
Old Jan 30, 2019 | 4:32 PM
oilcanhenry's Avatar
Engine size?
Old Feb 8, 2019 | 2:52 PM
SBchevyfan's Avatar
Two heads so it's a 4.3. Have you located the casting number on the block for reference?
Old Feb 11, 2019 | 7:26 AM
Lucn920's Avatar
Yep im pretty sure the only option for the blazers was the 4.3, but I've got it all figured out now. There is are a few different casting numbers for the heads. One of mine was 113 with bolt down rockers and the other was the 772 with ball and stud rockers. It was the 772 head that had huge crack in it and the other one was still good. I got a remanufactured 113 head to match the good one as well as a set of roller rockers and pushrods (theyre different lengths for different types of rockers) to match the other side. Just gotta finish putting it all back together and hopefully she'll be all good.
Old Feb 11, 2019 | 7:40 AM
Glad that you have this issue solved, Lucn920. I hate it when people do shoddy work, like the previous owner apparently did.
Old Feb 11, 2019 | 9:26 AM
Lucn920's Avatar
Thanks! and dont even get me started on that lol. I had to get new oil cooler lines too cuz those things are supposed to be crimped and someone had cut it (god knows why) and then slipped a hose over it and put a hose clamp on there. It was only a matter of time before that thing blew and I lost all my oil so thank god we noticed that.
