S-10 & Blazer 1982-2005
A Few ?s
Old May 13, 2010 | 3:26 PM
stock s10's Avatar
Default A Few ?s
First off I have a '96 S-10 with stock motor with exception of spacer K&N intake and Hypertech tuning. Anyways my questions are as follows:
1. What is the lb/hour rating of the mechanical "spider" injectors
2. Is there a known intake/injection system swap that gets rid of the spider but keeps all the stock equipment(ie. heads, fuel lines thermostat housing, etc. etc. want to not have to do a bunch of modifying to my top end to get rid of the spider).
I quess that's it for the ?s any and all info is helpful and appreciated and thanks ahead of time.
Old May 13, 2010 | 4:35 PM
maxxman04's Avatar
there isn't anything that will get rid of the spider itself, but there is a conversion kit that converts the problematic stock spider to an actual multi port injection unit, which puts the actual injectors at the heads instead of the center of the intake. takes 3 hours or so to swap in. i did this to my 98 tahoe, good results. quicker start, better throttle response, a little better mileage, and a bit more power. total cost should be under $400 with all gaskets and such. check local parts store, or online.
Old May 13, 2010 | 6:14 PM
stock s10's Avatar
I've searched for this conversion and can't find it. Who makes it? Did you do that conversion on a 4.3L V-6?
Old May 13, 2010 | 6:22 PM
maxxman04's Avatar
http://www.oreillyauto.com/site/c/se...996&vi=1061075
you will see it listed. mine was for a v8, but same procedure applies.
Old May 13, 2010 | 7:22 PM
stock s10's Avatar
So this conversion kit takes out the mechanical "spider" and replaces it with actual injectors? Do the injectors go inside the intake like the "spider" or does it go on the outside like a "typical" multi port injection system?
Old May 13, 2010 | 8:57 PM
MDTAHOE's Avatar
Professional Mechanic
Inside like the original
Old May 13, 2010 | 9:11 PM
maxxman04's Avatar
like MDTAHOE says, it looks exactly like the stock spider, fits right in place of it.
Cheesehead
Sep 5, 2014 9:22 PM
nichole120
Mar 9, 2012 6:59 PM
carolelynne87
Jul 13, 2007 10:33 PM
Chimaera
Site Feedback
Jun 15, 2007 1:57 AM
1hot650r
Dec 17, 2006 5:17 PM
