S-10 & Blazer 1982-2005
FUEL PROBLEM
Old Nov 4, 2006 | 10:28 PM
chevymandan's Avatar
Default FUEL PROBLEM
i have a 92s10 ext 4.3l tbi 4x4 140,000 mi . well to start a little background ..... bought the truck need a new tranny(so i thought ).
so i put tranny in . ran ok afterwards till i noticed oil pressure drop ... oil pump went out ....soooo i did a motor swap .... ran ok but
when i shut the truck off it wouldn't start ... NO FUEl ... replaced fuel pump .. started fine ... let it set moved it to sell (after charging new battery ) fired right up . found gas leak ... fixed gas leak ....started up no problem drove around pulled back in the driveway ..
shut it off figured i would try to start it back up but not getting fuel ???? anyone give me any ideas to what the problem may be ??????
thanks chevymandan
Old Nov 7, 2006 | 12:32 AM
70mopar's Avatar
Default RE: FUEL PROBLEM
hmmm......not getting any fuel......what kind of pressure r u getting?do u even hear the pump? have u checked all the grounds?
Old Nov 7, 2006 | 11:27 AM
golfer's Avatar
Sounds like it only does this when the engine is "hot soaked ??
May have something to do with the pressure regulator bleeding back.
You could try putting on a pressure guage and see if the pressure drops rapidly after the engine was running.
Old Nov 10, 2006 | 4:18 AM
well i took the fuel line off at the tbi and getting good pressure......buddie of mine at
parts store had same problem ....had me bring in ignition modual to test...ALL but 1
sector bad .... drove it to work . shut it off . wouldn't start again . worked my 8 hrs ,
come out started right up . coil maybe ???? dunno thru the sepintin belt on the way
home .....
chevymandan
Old Nov 10, 2006 | 4:25 AM
good pressure ... hear the pump well. grounds are all good ..
(had to repair and replace them personally)
Old Nov 10, 2006 | 4:04 PM
golfer's Avatar
ORIGINAL: chevymandan
home .....
chevymandan
So the pressure stayed up after you shut off the engine ??
Old Nov 10, 2006 | 10:26 PM
70mopar's Avatar
so did u replace the ignition module? or r u still running the 1 that came up faulty?
Old Nov 13, 2006 | 1:11 AM
i replaced the faulty one , now on hold working on it .....
Old Nov 13, 2006 | 1:13 AM
yes it did
hunter10220
May 18, 2011 8:37 PM
scottkern3
Dec 7, 2009 7:53 PM
harascho
May 11, 2009 2:10 AM
MrPuzzlez
Jan 4, 2009 12:02 AM
