S-10 & Blazer 1982-2005
have you had this happen
Old Jun 17, 2021 | 8:49 PM
kazkettman's Avatar
Default have you had this happen
ok so this only happens when the weather is warm outside, when im on the freeway..about an hour into driving my 4.3L s-10 starts to stall out, now if i floor it it will start to go again but if i dont it will die....now i can restart it and it'll go but wants to soon die after , unless i punch it again. if i have the rpm's up high it doesnt have any problems but in 5 oclock retard hour traffic its kinda hard(i have to drive like a psycho) whats wrong with it.......1995 s10 4.3l
runs perfect when in cold weather
Old Jun 18, 2021 | 8:19 PM
oilcanhenry's Avatar
If you can find an OBD I scan tool that would help. Sounds like a fuel problem to me. Might want to check your fuel pressures. Have you replaced anything yet? I'd certainly check out your ignition system components, as well.
Old Jun 18, 2021 | 11:00 PM
sounds like its running rich. all the conditions you describe it running well are when it needs a larger fuel demand...cold..wot. What do the plugs look like...black=rich
check the ect sensor reading and 02 sensor readings...if they are askew it could run rich. h igh fuel pressure as och said is another cause to be rich.
poisondart
Jul 28, 2013 2:26 PM
Bondobudie54
Jun 27, 2012 7:12 PM
vetsir
May 4, 2010 11:44 AM
mnchevy
Feb 15, 2010 12:23 AM
vialcuatro
May 3, 2007 10:07 PM
