S-10 & Blazer 1982-2005
help!
Old Sep 7, 2009 | 6:48 PM
shawnlcarlson's Avatar
Unhappy help!
i have a 1995 blazer,and recently decided to kiss a phonepole with it. it hit on the left side of the front end,less than an inch away from the headlamp,but didnt crack it(luckily).the front left turn lamp was obviously crushed,but now the brake lights stay on,unless i take the fuse out.any clues what is wrong?thanks for the input.
Old Sep 8, 2009 | 5:11 PM
Siliconasp's Avatar
replace the socket and check for grounds in the wires leading back to the main harness, and you should be fine. Time to visit your local U-Pull-It or Pick-A-Part yard.
Old Sep 8, 2009 | 5:17 PM
"sic"'s Avatar
we have both here in Bak Cali
Old Sep 8, 2009 | 5:26 PM
DeeZ's Avatar
Ride of the Month
August 2009
Sorry to hear about your situation. I feel for you as I'm in the very same situation except I fear a little worse. Good luck with everything.
Deez
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
