S-10 & Blazer 1982-2005
Help diagnosing problem: Oil in coolant`
Old Dec 27, 2013 | 3:30 PM
masonmd's Avatar
Default Help diagnosing problem: Oil in coolant`
I have a 1996 Blazer 4.3L 4WD. I found oil in my radiator and overflow bottle. I checked the oil and there is no coolant in the oil. As I understand it there are three likely causes: blown head gasket, intake manifold gasket, or oil cooling line inside the radiator leaking. I got a combustion leak test and the results are negative for combustion gases in the coolant. That rules out the blown head gasket. How can I test if the problem is the intake manifold gasket or the oil cooling system in the radiator?
Right now I disconnected the oil cooling lines from the radiator and pressurized the radiator to see if I could get the coolant to leak out of the oil cooling line holes, but so far no coolant has leaked out of the openings.
I appreciate any help. Thanks. Mark.
Old Feb 22, 2014 | 10:41 AM
garrid's Avatar
I think you are close to your problem, I had this problem and it was the intake gasket, some how this is a common problem on 4.3 v6, you will probably find the drivers side is where the leak is, I when ahead and replace both side. Hope this helps you.
Old Feb 25, 2014 | 6:53 AM
donald_archer's Avatar
Default I had the same problem
I have a 4.3 L V6. Around 90,000 miles i had the same problem. It was the intake manifold gasket. Had it changed 3 years ago.
dlaroche
Oct 29, 2014 7:17 PM
OraxThay
Jun 16, 2014 12:41 PM
barnesam
Apr 11, 2012 10:04 PM
countryboy92
May 20, 2011 9:55 PM
daddytaz
Jan 9, 2011 10:29 PM
