S-10 & Blazer 1982-2005
help with restoring 86 s10
Old Nov 12, 2010 | 12:58 AM
wbreslin951's Avatar
Default help with restoring 86 s10
Hi all, I just bought an 86 s10, I'm not really familiar with the workings of this thing and I really don't want to buy a repair manual right now, I'd rather use the $ on parts. Any ways, the truck runs and drives good, I saw a few jimmy rigs under the hood but nothing too crazy, its missing the ac compressor but I really don't care about that. it also has the ses light on, im just trying to figure out where to start, I wanna fix whatever it is that needs to be fixed but I have to find what ever it is that may be fubar'd. what should I look for?
Old Nov 12, 2010 | 8:45 AM
Welcome to the forum...
as for the SES, I would have the codes read, write them down, clear them and then see what comes back and go from there...
I suspect it being and 86' the codes will most likely apply to some emissions issues...
Old Nov 12, 2010 | 10:07 AM
Ses light codes are
12 - diagnostic mode
42 - electronic timing system
now what? Lol
Old Nov 12, 2010 | 11:16 AM
I'd say clear them by disconnecting the battery for several minutes and see if it comes back and go from there...
Old Nov 12, 2010 | 1:39 PM
gotstylez's Avatar
Originally Posted by wbreslin951
Ses light codes are
this isnt really a code.. its just telling you that your are in diagnostic mode...jus thought i would throw that out there lol
Old Nov 12, 2010 | 2:08 PM
i found a part, not sure what it is, its mounted on the air cleaner housing, and has a 3wire connection going into it, with a vacuum hose coming off into the throttle body, there's also a vacuum hose missing between the air cleaner and the throttle body, seems like an easy fix. the timing is off a little bit, so i thought maybe this part on the air cleaner with wires has something to do with the electronic timing sytem cuz thats what that code is for, but i really dont have a clue
Old Nov 12, 2010 | 2:19 PM
Post a few pictures of what you are looking at , someone may recognize it and be better able to give some guidance...
Old Nov 13, 2010 | 10:22 AM
It was the map sensor, its all good now that I got the vacuum lines hooked up. As far as therr error codes go, I'm pretty sure theres an open or grounded conductor between the distributor and the ecm, I'm gonna check it out a little later today and see what I can find
Old Dec 14, 2010 | 11:51 PM
mattieshane's Avatar
Default code 42
What was your fix for the code 42?, I have an 88 S-10 with code 42,and its drivin me nuts!.
estowe06
Aug 19, 2011 9:36 AM
corey1518
Oct 3, 2010 5:16 PM
gerkendave
Nov 12, 2008 7:32 PM
small block nut
Mar 16, 2008 7:06 PM
