S-10 & Blazer 1982-2005
Help to specify a rear end!
Old Dec 13, 2012 | 11:20 PM
Alan Klain's Avatar
Question Help to specify a rear end!
OK help from all you S10, Sonoma, Blazer guys would be greatly appreciated!! After lots of research and differing direction and opinions I should have started here I guess.
I have a 1937 Chev 2 door flat back sedan and I need a complete hub to hub differential about 54 inches from backer plate to backer plate.
Ideally I would like 3.73 (maybe 3.42 gears) with as large a ring gear as possible (8 inch or more?) and disc brakes would be a nice touch. I would sacrifice disc brakes if you can direct me to a decent “conversion kit” solution after the fact. The essential things are the 54” or close to, the 3.73 or 3.42 gears and the larger ring gear.
I am told that the “Sport” model of S10 would have the larger ring gear? I was also told that the 2 wheel drive models were the shortest of the bunch but does not come with disc brakes? Help anyone!
Come to my rescue and tell me what make and model and a year range I am looking for.
Many thanks. Alan from Alberta Canada.
hardbalance
Apr 30, 2015 10:57 PM
TASpinney9110
Mar 15, 2011 5:54 PM
hydrodriver
Astro
Dec 11, 2010 8:52 AM
Nagromis12
Mar 13, 2009 2:39 AM
biglg
Jan 28, 2008 8:26 PM
