leaking water when it rains
i hope someone can help me! my 91 s10 2wd 4cyl. 5 speed. it leaks water on the passenger and drivers side floor whenever it rains. the leak on the passenger side looks like its coming from behind the heater box. cant see where the leak is on the drivers side. the truck only leaks when it rains and it is making me crazy!!! please help
thanks for helping me i appreciate it. i pulled the carpet and the dash out there is nothing in the truck but a seat and steering wheel. the water is coming from behind the heater box. so i pulled the box out and sealed it against the firewall. but it still leaks from back there. and it leaks on the driver side too. not sure where that leak is coming from
It could be a bad windshield seal, i had a problem with my rear window where the glass installer didn't fully seal my window when a lacrosse ball blew it out. take a hose, turn it on just so that it slowly flows and then search for the leak... yeah, my rear carpeting was moldy as all he**, cleaned and replaced the "cushioning" underneath it
My 1995 S-10 Blazer leaks from fresh air intake to passenger's side. Down the corner junction of firewall and kick panel to floor where it pools. I ran water slowly from hose over black cowling starting from outboard end to center on passenger's side. The leak started when the hose got to the fresh air intake. What needs to be done to gain access to the area in question?
swamprat
I don't remember if Peter got the leak figured out or not. I remember him pulling up carpet, oh that was on the Drivers side to find the wires for the seat control. They were in a bad place and were damaged. He re routed them and fixed them.
Hopefully someone else can help you with that.
I don't know if he told you, but we went to Cleveland clinic on the 11th of October for surgery on his ostomy. Things went bad, very bad. He passed away and went to the angels on the 1st of November.
Emily
Emily
swamprat
Emily
Emily
I took mine off and the drain hole was clogged (passenger side only), I merely flushed it out with a hose and everything is back to good.
Sorry to hear about Peter, R.I.P.
Thanks for the info on the 'fix'. If it rains in that side again I will know what to do.
Peter was my friend and also my husband. We dated in high school and then went our own ways. A few times in those 40+ years we talked. We got back together in 2005. Married in early 2006. So we were back together 5 years - and the past 3 were medical issues for him. And some for me [back problems], but mostly him .... That is all the time we were allowed, but it was good.
Emily Cummins
Emily Cummins
