S-10 & Blazer 1982-2005
LOCKED OUT
Old Mar 8, 2007 | 7:24 AM
Matt Luke's Avatar
Default LOCKED OUT
Anyone have any suggestions on how to get inside my truck without calling a locksmith? I locked all my keys inside yeah I know smoooth! [&:]doh!
Anyone know where to get good deals on parts for these older Chevy's?
Thanks for the input!
Old Mar 8, 2007 | 1:40 PM
shnormo's Avatar
Default RE: LOCKED OUT
Well what year are you talking about.If you go to a tool store like Harbor Freight, you can pick up a slim jim kit.
Old Mar 8, 2007 | 2:23 PM
Matt Luke's Avatar
It's a 94 s-10 4.3 ltr extended cab....is it easy to slim jim into?
Old Mar 8, 2007 | 3:22 PM
dragonrpc's Avatar
definetly try a slim jim, or hanger depending on your door pins.
do you have a wing mirror or split rear, those are pretty easy to get open as I understand.
I have seen worst case break the window, and get it replaced (many same day services) or lock smith should also be able to get you in
good luck
Old Mar 19, 2007 | 9:41 PM
JPetrucci84's Avatar
AAA will do it if you happen to have a subscription. You probably would've mentioned that, though.
Old Mar 21, 2007 | 9:18 PM
CrashNburn's Avatar
if you have power locks this works... bend a coat hanger
___
___ |
/ \ |C
A \__/
B
roungly like that. slide it into the door (through the bottom window trim) from A to B keep end C outside the window. once you get it into the door turn it so it hits the inside of the door, the lift up.. A should be inside your truck. now use C to move A to hit your button....
Hope that make sence
Old Mar 27, 2007 | 2:20 PM
Hell I just made a lasso type device with a coat hangar and was able to pull the handle from the inside with it.
Old Apr 23, 2007 | 8:16 PM
gtxracing's Avatar
ORIGINAL: JPetrucci84
What a heck of a response LOLOLOL. Also this slim jim talking is starting to become a commercial knock off LOL
Old Mar 17, 2024 | 5:27 PM
Upacrk's Avatar
Default 2000 S10 LS ex cab locked out
Hanger not stiff enough. Unscrew radio antenna, wedge door, straight and stiff enough to push power lock button. A miracle!
___
___ |
/ \ |C
A \__/
B
Hope that make sence[/QUOTE]
Spoiler
TeamK
Avalanche
Nov 1, 2010 9:48 AM
alexdevlin
Apr 9, 2007 1:29 AM
mse4e
Jul 24, 2006 2:06 AM
oldtimer50
Jul 14, 2006 10:14 PM
