S-10 & Blazer 1982-2005
My Blazer has a rough idle
Old Dec 11, 2011 | 8:31 PM
kc wolf's Avatar
Default My Blazer has a rough idle
I have recently replaced the Intake Manifold Gasket on my 2000 Blazer,, it has a 4.3L with just over 206,000 miles.. I'm pretty sure i have put everything back the way it was before, and now i have a idle problem, plus sitting at a light or stop sign, it acts like it wants to choke out, or hesitate at first.. Then once it starts moving, it is fine.. the shifting of gears, and maintain speed,, and no problem in passing others.. first i thought i had not put the Distributor back in correctly, or it could be the Cap & Rotor (as i have seen on other postings)... Any suggestions or remedies would be greatly appreciated...
Old Dec 11, 2011 | 9:01 PM
MDTAHOE's Avatar
Professional Mechanic
Did you take the upper intake off the lower?
Old Dec 12, 2011 | 6:56 AM
kc wolf's Avatar
Yes i did remove the upper part also.
Old Dec 12, 2011 | 7:00 AM
MDTAHOE's Avatar
Gets some carb cleaner or brake clean or starting fluid. Start the truck and spray where the fuel unit comes through the upper, if it effects the it runs it is not sealed. It is very tricky to get that back together. For the future you do not need to remove the upper from the lower to do the intake gasket.
macmommy
Apr 22, 2020 1:23 PM
Sethyates72
Feb 1, 2014 7:53 AM
gscrippler
Jun 14, 2009 9:35 PM
07LS
Mar 28, 2007 4:35 AM
ultra7350
Oct 29, 2006 9:39 AM
