S-10 & Blazer 1982-2005
Mystery Trans/TCase leak, 1990 Blazer 4.3L/Automatic Overdrive
Old Aug 16, 2008 | 11:56 AM
ironclad's Avatar
Default Mystery Trans/TCase leak, 1990 Blazer 4.3L/Automatic Overdrive
Unsure what transmission this is, 700R4? There is a throttle valve or kickdown cable present, and it is definitly an overdrive, behind a 4.3L.
If the vehicle is driven above 50mph, the tcase ends up coated with ATF on the driver side, near the front driveshaft yoke, while the transmission stays dry. The ATF level in the transmission does drop.
We do see a servo cover there, but it doesnt look like an obvious leak there. Because it only happens when driving at speed, everything blows back.
Any thoughts on this? Would this meet the symptom of a tranny output shaft seal leaking? Something about the vacuum lines on top of the tcase?? we've been researching this a bit, but are unsure on where to start..
Any suggestions would be appreciated.. The vehicle does run fine, all shifts are proper..
Thank you!
Old Aug 20, 2008 | 9:12 PM
ktm521's Avatar
Default RE: Mystery Trans/TCase leak, 1990 Blazer 4.3L/Automatic Overdrive
Trans is overheating and pushing fluid out of the overflow tube on the trans.
racerdonnie13
12
Apr 21, 2014 6:45 PM
snake91876
Oct 13, 2012 3:41 PM
blanning
Apr 14, 2010 5:26 AM
TRWFan
Mar 24, 2009 10:07 PM
rattlehead
Oct 25, 2005 3:25 AM
