S-10 & Blazer 1982-2005
Oil Change
Old Sep 28, 2007 | 4:19 PM
86_S10's Avatar
Default Oil Change
ok, my S10 is just about to hit 130,000 miles, and I think its just about time for another oil change. First off, i have little knowledge about oil changes (I have always taken it to jiffy-lube). And second off i have no idea of what viscosity of oil to use. So i would like to get this done this weekend. Thanks, 86_S10.
Old Oct 2, 2007 | 3:08 PM
sickvortech1's Avatar
Default RE: Oil Change
Hello, i see why you want to diy the oil, jiffy lube gets caustly every 3000 miles.im no pro but I have tuned a lot of wrenches,so 10w 30 sae is a good standard viscosity range for most vehichals, hot or cold
weather.. but not extream cold -5w 30sae for that .I use mobil 1 / 5000 mile oil in my high milage 4.3 v6 also a purilator oil filter. its best to change your pvc valve and air filter at the same time. hope this helps and i would suggest a haynes manual for tune ups and other min / majrepair info.
Old Oct 2, 2007 | 8:00 PM
86_S10's Avatar
alright, thanks a bunch..i will keep the hanes in mind. 86_S10
in2pro
Nov 19, 2015 5:36 PM
PeterPiper
Sonic (Aveo)
17
Feb 6, 2010 1:10 PM
Toby T
Mar 14, 2008 5:16 PM
Big D
Jan 10, 2008 6:53 PM
digdug
Feb 4, 2007 3:08 PM
