S-10 & Blazer 1982-2005
Oil filter adapter lines 99 blazer
Old Dec 30, 2008 | 6:26 PM
scoony's Avatar
Default Oil filter adapter lines 99 blazer
I am replacing the lines that run from the oil filter to the engine block. I got the bolts out but cannot remove the old line. The rear fitting is too large to fit between the engine and the axle. I have seen one recommendation to cut the rubber section of the lines and that would work, but I am worried about getting the new line in there. There has to be a trick to this. Please help!
Old Dec 31, 2008 | 8:36 AM
johndb's Avatar
Default RE: Oil filter adapter lines 99 blazer
I don't mean to sound stupid but can you not just lower the axle or raise the engine a bit?
Old Dec 31, 2008 | 1:21 PM
scoony's Avatar
Thanks,
We did jack up the engine. Just needed jacked up a hair to get enough clearance so we did not have to unbolt the mount.
KGJC616
Jul 10, 2012 4:03 PM
klturi421
Jun 7, 2012 3:05 PM
ajizzle_84
Aug 17, 2011 6:41 AM
burbandad
Dec 19, 2010 12:11 AM
lukemoore646
May 31, 2009 5:19 PM
