S-10 & Blazer 1982-2005
P0172 95 4.3 vortec running rich need help
Old Sep 11, 2018 | 10:18 PM
  #11
970joe's Avatar
I work in a shop with 9 other diesel techs and all of us are scratching our heads. Lol
Old Sep 11, 2018 | 10:19 PM
  #12
geo1's Avatar
Why did that just show 0 rpm?what about at idle?
Old Sep 11, 2018 | 10:21 PM
  #13
geo1's Avatar
I drink beer,lots of it,and I'm bald now, from headscratching
Old Sep 11, 2018 | 10:23 PM
  #14
970joe's Avatar
That was just a screen shot taken with the KOEO. I don’t have the truck with me tonight. Drove the wife’s car to work. Monitoring the sensors while driving the past few days the advance is always negative usually-20 to -35 CYL #1. I’ll screen shot it when I get a chance.
Old Sep 11, 2018 | 10:24 PM
  #15
geo1's Avatar
Before buying a 02,introduce a vacuum leak at idle,see how low the 02 will read,if it goes down it's fine
Old Sep 11, 2018 | 10:25 PM
  #16
970joe's Avatar
Have you ever seen a LTFT go to a preset value and stay there? Whiskey man myself. The techs think a good ol stock of dynamite and a Diesel engine drop in should solve the problem.
Old Sep 11, 2018 | 10:26 PM
  #17
970joe's Avatar
I’ll try that tomorrow morning. It had a huge vacuum leak at the accessorie line that I fixed while diagnosing the code.
Old Sep 11, 2018 | 10:32 PM
  #18
geo1's Avatar
Max is 25% either way,+or-,so a uncontrollable problem, not sensor related, something out of the pcm's grasp,fuel being sucked in from fuel pressure regulator vac.line?evap. canister fuel soaked?tps reading to high?
Old Sep 11, 2018 | 10:49 PM
  #19
970joe's Avatar
pressure regulator is inside of the plenum and uses a small hole in the shell for manifold vacuum and it isn’t leaking. Tested it three times now. I took the vacuum line for the fuel canister off to isolate it from the system thinking it was sucking to much fumes in on the purge cycle. Even isolated from that from the system it popped the code. Injector is not leaking. Poppets aren’t leaking. Fuel lines inside of plenum aren’t leaking. Used propane around plenum and upper manifold to see if it had any vacuum leaks. Nothing. I’m starting to question the Vehicle control module (PCM) on this truck wondering if it’s bad.
Old Sep 11, 2018 | 10:53 PM
  #20
970joe's Avatar
This is what the inside of the plenum looks like. The CFI spider is located inside the intake plenum along with the spider fuel lines and pressure regulator. It’s an all in one unit. Mine is new and been in for around 15 months.
