S-10 & Blazer 1982-2005
P0172 95 4.3 vortec running rich need help
Old Sep 11, 2018 | 10:56 PM
  #21
geo1's Avatar
Rats,so the vacuum leak for 02 test will show,(a)02 is working or not,right now it's .8 or so,with leak,hopefully it goes down to .2,so if it drops(b)pcm?
Old Sep 11, 2018 | 10:58 PM
  #22
geo1's Avatar
Got the pic.,I get confused on the cusp years,seen some variations from obd1 to 2
Old Sep 12, 2018 | 7:03 PM
  #23
970joe's Avatar
Updated my software for my scanner today and did the induces vacuum test. It didn’t change the fuel trims. But I did find out that the catalyst is toast and is more than likely partially clogged and causing too much back pressure on the engine. I suspect at this point that it’s causing incomplete combustion and not slowing enough fresh air into the cylinders and causing the rich running condition. So for now the project is on hold until I have the time and money to replace the catalyst.
Old Sep 12, 2018 | 7:06 PM
  #24
970joe's Avatar
I also plan on changing both 02 sensors out with the catalyst. At this point everything upstream checks out good. So I’m honestly hoping the new sensors and cat will be the solvation to the code coming back.
Old Sep 12, 2018 | 7:07 PM
  #25
geo1's Avatar
How low did the 02 go?and for cat.,purchase some cataclean,20$ at all part stores,works wonders
Old Sep 12, 2018 | 9:27 PM
  #26
oilcanhenry's Avatar
Scotty Kilmer has a good Youtube vid on cleaning out a CAT too. Worth a look see.
Old Sep 12, 2018 | 9:29 PM
  #27
geo1's Avatar
Cool,thanks
Old Sep 18, 2018 | 11:14 AM
  #28
970joe's Avatar
Ok so
cleaned out the Cat and surprisingly it worked to stabilize it because it was fuel soaked and not damaged I lucked out on being able to clean it out. I just used a garden hose and simple green soap in a bucket and then used my vacuum / blower to air dry it out before putting it back into the truck. But it still has the fuel rich condition. Surprisingly enough I found a simple and ingenious way to check the fuel regulator on the vehicle using an air gun. and will post the link.
Old Sep 18, 2018 | 11:15 AM
  #29
970joe's Avatar
Here is the link to the video.
Old Sep 18, 2018 | 11:19 AM
  #30
970joe's Avatar
It actually worked. Sprayed the face of the fuel pressure regulator with air and fuel mist was expelled from the vacuum hole proving that the vacuum diaphragm has a pin hole leak. Next step is to replace the regulator sometime this week and see if that solves the problem.
