S-10 & Blazer 1982-2005
P0301 dtc
Old Nov 7, 2012 | 11:13 PM
Bobcat1963's Avatar
Default P0301 dtc
I just bought a 2002 Blazer with a 4.3. It had a DTC P0301 #1 Cylinder misfire. I replaced the spark plugs, wires, distributor cap and rotor. The code came back after about 15 miles. It has a rough idle. It will occasionally 'stumble' under load. I checked the throttle position sensor with my scan software. It measures the % applied. It seemed to measure okay from 0-100%. I'm thinking injector, crank or cam sensor?
Old Nov 18, 2012 | 9:58 PM
Bobcat1963's Avatar
Checked the compression on #1 cylinder, 90 psi. Squirted oil in the cylinder, it didn't change. The other cylinders are around 140 psi dry. Sounds like a burnt valve or blown gasket.
Old Nov 19, 2012 | 8:05 PM
armystrong928's Avatar
i would go with the burnt valve part
halverson82
Jun 19, 2011 9:51 AM
Mud_Truckin
Sep 12, 2009 7:32 PM
temills
Dec 16, 2006 6:35 AM
calwoodbutcher
Jul 31, 2006 2:07 PM
calwoodbutcher
Jul 28, 2006 5:14 PM
