S-10 & Blazer 1982-2005
service engine soon light
Old Aug 2, 2011 | 5:09 PM
ken1950's Avatar
Default service engine soon light
I'm new here and you've probably heard this many times. Can you pull your codes without a reader???? If so how.. Don't have a book yet, but will ordering one soon. My (service engine soon light ) came on today . I checked the gas cap and disconnected the battery and reconnected to see if the light would go off . The light came on as soon as i turned the key on. Any help would be really nice (i checked the PVC valve and its good) 2001 chevy s-10 pick-up v6
Old Aug 2, 2011 | 5:55 PM
kevinkpk's Avatar
Don't think so with an OBD11, get a cheap scanner or take it to an auto parts store that will scan it for you.
Old Aug 3, 2011 | 10:53 PM
dab11999's Avatar
There is a way, but I'm not certain about yours. The check engine light flashes any active fault codes. Something like turn the ignition switch on and off 3 times, leaving it on the third time. It will flash a beginning test code of 12, which is one flash then two flashes. Ends with code 12 also I think. Something like code 32 would be three flashes then two flashes. It's not a precise diagnosis, but it gives you a starting point.
Old Aug 4, 2011 | 7:01 AM
ken1950's Avatar
Thanks i'll give that a try before i buy a reader. No local places will read it without charging you
texasdontholdem
Jan 4, 2011 2:26 AM
jcv22jr
Feb 17, 2007 1:09 AM
chevylvr
Feb 10, 2007 5:48 PM
kimoZ71
Dec 12, 2006 10:36 PM
hopkinstx
Sep 17, 2006 12:29 AM
