S-10 & Blazer 1982-2005
Stalling at stops
Old July 8th, 2014, 6:28 PM
sflas10's Avatar
Default Stalling at stops
I have a 94 s10 2.2l 2wd. Starts up and runs fine. After it warms up it wants to stall at stop lights, unless I keep my foot lightly on the gas. If I take my foot off the gas it stalls. If I am driving, it accelerates and drives fine. I cleaned the IAC, it had carbon on it. Still doing it. Any ideas?
Old July 9th, 2014, 8:22 AM
sledge.impy's Avatar
Sounds like the tcc solenoid. Unplug it first if you can. You'll lose fuel economy, but it will stop stalling for now.
http://www.google.com/search?q=1994+s10+tcc+solenoid
Old July 9th, 2014, 10:19 AM
sflas10's Avatar
Everything from that link shows an automatic transmission, my truck is a manual transmission.
I am leaning towards heavy cleaning of the throttle body, clean the iac again and ohm test the iac. Just seems even when it doesnt stall after the engine warms up, it still idles low. Thoughts?
Old July 9th, 2014, 10:25 PM
Oops, sorry, you didn't say in the original post, and you don't mention your mileage. Sounded like classic tcc solenoid. UGH..
Have you done any research on loose main bearing end play that would cause a stall?
SuperTexan
Silverado & Fullsize Pick-ups
November 27th, 2013 9:15 PM
stanman
Camaro
January 7th, 2012 4:12 AM
silveradolt1
May 4th, 2008 11:13 PM
tdken
March 20th, 2008 7:11 PM
DEI
December 18th, 2007 9:28 PM
Quick Reply: Stalling at stops
