S-10 & Blazer 1982-2005
Trailer wiring
Old Jul 15, 2010 | 4:51 PM
danb113's Avatar
Default Trailer wiring
Can anyone tell me where I can find the wires for a electric brake hookup under the dash in a 99 blazer? I found the power wire by the fuse block under the hood, and I believe the brake (blue) wire there also. Just need to know under the dash, Thanks
Old Jul 15, 2010 | 5:00 PM
maxxman04's Avatar
there isn't a factory plug for a brake box in 99. the red wire under dash is for auxiliary power to trailers, the blue is indeed for the trailer brakes.
your control box should have four wires: red, black, blue, white.
red wire ties into the vehicles brake light switch/ wiring. you may have to use a test light to find which wire off brake light switch has power when brake pedal is applied. in a GM rig, i believe it is either a yellow or white wire
black wire is a 12 volt power
white wire is ground
blue wire ties into blue wire underhood
Old Jul 15, 2010 | 5:04 PM
maxxman04's Avatar
http://www.easternmarine.com/em_stor...e_diagram.html
Old Jul 15, 2010 | 5:07 PM
danb113's Avatar
ok, thanks for the help.
intheknow
Jul 24, 2014 10:38 AM
billhemingway
May 4, 2010 3:53 PM
mgoddard
Aug 2, 2007 4:51 AM
connman119
Aug 23, 2006 9:13 PM
