S-10 & Blazer 1982-2005
Truck will not start after sitting for months
Old Oct 15, 2022 | 9:05 AM
JCLN's Avatar
Default Truck will not start after sitting for months
Newbie here. Just joined today.
2003 Chevy S10, 4x4 crew cab. 4.3 V6, about 102,000 miles.
I have the above truck. It has been sitting for months. The last time I used it it would not start, but would crank over fine. I squirted some starting fluid into it and would fire and run for a few seconds, so, I assume that the plugs are firing. I screwed around with it and jiggled some wiring connectors on the top of the motor and then she fired up and ran fine. I drove it around for a bit and everything seemed OK, so, I parked it.
Then, about a week or so ago, I tried to start it up and she would not start. Again, I giggled the wiring connections on top of the motor, but she still would not start. Squirted some starter fluid into the throttle body and she started and ran for a few seconds but would not stay running. I added about 10 gallons of fresh fuel and she still would not start.
It seems to be an issue with not getting fuel to the throttle body but I do not know how to check that. When I turn the key on, I do not hear any noises (like a fuel pump running).. The battery is fully charged, no fuses are blown.
Is there a way that I can put a jumper wire someplace to turn on the fuel pump without having to crank the engine over? I did remove the fuel pump relay and exchange it for another relay and nothing changed.
What steps should I take to diagnose and fix this?
Thanks for any tips.
Old Oct 15, 2022 | 1:04 PM
kevinkpk's Avatar
Pull the fuel line off, try to crank it, no fuel, replace the pump. That is what it looks like is your issue.
Old Oct 15, 2022 | 1:33 PM
JCLN's Avatar
Where do I take the fuel line off? At the throttle body or underneath the truck or ???
I assume that if the pump needs to be replaced that I need to jack the truck up at the *** end, empty the tank and drop it? That would be tough because my fat body will not be able to get underneath the truck without a lift. Any easier way to do that? It would have been nice to have an access cover in the bed of the truck to get to the pump.
Old Oct 15, 2022 | 5:15 PM
kevinkpk's Avatar
Throttle body is fine.
Old Oct 15, 2022 | 5:17 PM
kevinkpk's Avatar
It is a pain. My Mazda has an access panel for this job, sorry Chevy builds their stuff to be serviced by a dealer.
rmang
2007 - 2013 (GMT900)
Nov 25, 2019 10:56 PM
ChevySilverado
Jul 29, 2015 11:08 AM
holyearth
Nov 10, 2009 7:09 AM
92K5
K5 Blazer
Aug 22, 2007 11:14 AM
jecudoc
Jun 4, 2007 12:33 PM
