S-10 & Blazer 1982-2005
Wheel bearing quick question
Old Oct 7, 2020 | 4:30 PM
Jamesg408's Avatar
Default Wheel bearing quick question
I have an old 94 s10 truck. I changed all the front wheel bearings and now the rear is starting to make noise. I opened up the differential and checked the inner bearings and they look good so I know the outer ones in the axle is the problem. The guy at the parts store said the ones in the differential are the important ones. He also said the outer ones in the axle will just make noise and not cause any damage. Is this true? I really want to avoid this job. Thanks
Old Oct 7, 2020 | 7:32 PM
Little Bear's Avatar
No they are just as important, they are actually supporting the trucks weight going down the road. They go bad and you'll be replacing the axles too.
gmlover
Oct 30, 2013 8:24 PM
Fishinfooleric10@aol.com
Sep 28, 2012 12:45 PM
Allan In NE
Dec 27, 2011 7:07 AM
VanGo
Jan 21, 2011 8:40 AM
Shaun_95
Nov 17, 2009 12:39 PM
