S-10 & Blazer 1982-2005
ZR2 problems
Old Oct 7, 2011 | 1:20 PM
wolfking42084's Avatar
Default ZR2 problems
I have a 02' S10 zr2 that is having some issues. I was wondering if anyone would share some thoughts and ideas. First, my heat will not work just idling. It seems the only time it will work is when going up a hill. As soon as I flatten out or go downhill, it blows cold air. Second, no matter where i have the fan set(feet, face, defrost, etc), going uphill, it will always switch to face. Any ideas? thanks guys
Old Jan 7, 2012 | 11:01 PM
taz3's Avatar
ONLY DO THIS WITH THE ENGINE COLD!!!!
It sounds like you're low on coolant, check the level in the reservoir cold and if that is good remove the rad cap and see if it's full too. If it looks full, you may have an air lock in the cooling system.
When going up hill the coolant is being forced via gravity back to the heater core, and because it is up high, the coolant drains out on flat roads back to the engine.
wolfking42084
Apr 20, 2009 6:13 AM
bobbie95poca
Feb 12, 2008 1:48 PM
mthomp
Dec 18, 2005 11:57 PM
Moralszr2
Oct 5, 2005 5:00 PM
