Transmission leak
Old Jun 2, 2021 | 6:07 PM
Matt.J.'s Avatar
Default Transmission leak
I changed my transmission fluid to Dex6 about 1000km ago and I just noticed a transmission fluid leak. It mostly drips off the starter and looks like it's coming from the top of the bell housing. I am completely stumped on where it is coming from, if anyone has any ideas on how to fix/find that'd be great. It's a 4x4 4L60e, the pics are the leak.
Old Jun 3, 2021 | 7:51 AM
Was it leaking before the fluid change? Did you remove the pan to drain the old fluid? If yes then it is probably the pan gasket.
Old Jun 3, 2021 | 9:12 AM
Matt.J.'s Avatar
It didn't leak before the change and yes I took the pan off, but it is dripping from above the pan so that is why I don't think the pan gasket is the culprit
Old Jun 3, 2021 | 10:29 AM
Can you clean it up real good and then keep a close eye on it to see where it is coming from?
Old Jun 3, 2021 | 10:31 AM
Matt.J.'s Avatar
I'm almost 99% sure it is coming from the top of my transmission, I'm thinking it might be the vent? I'm going to have another look at it today
Old Jun 3, 2021 | 10:47 AM
If it is coming from the vent then there is a possibility that the transmission is overfilled with fluid.
jampg
Sep 16, 2019 7:28 AM
Jwald
May 14, 2017 1:35 PM
emb505
Mar 23, 2016 6:49 AM
Ar_lynn
Apr 1, 2013 9:05 PM
OleBones
Aug 2, 2008 7:05 AM
