Tracker 1989-2004
Platform: CAMI (Suzuki)
Tracker 101: intro to door panel removal
Old March 14th, 2024, 11:30 AM
L84sky's Avatar
Default Tracker 101: intro to door panel removal
This tutorial shows how to remove the passenger door panel.
The mirror cover has to be pulled straight back.
I used these body panel tools but any thin pry bar should work.
The mirror cover is held on by two plastic rivets.
The rivets pop into these two holes in the door frame.
When I pulled off the cover off one rivet stayed with the cover and one stayed in the door frame.
I used the rivet remover tool to recover it. Luckily neither the rivet nor the cover were damaged.
Once the mirror cover is off, remove the Phillips screw from the inside door handle.
Pull the handle towards the door hinges...
... and push off the plastic retainer from the linkage.
Remove the Philips screw from the door pull handle.
Old March 14th, 2024, 11:37 AM
L84sky's Avatar
These are the locatione of the seven plastic rivets holding the panel to the door.
This is what the rivets look like.
New rivets are available on Amazon.
Pop the power window switch out of the panel.
Use a small screwdriver to release the locking tab.
I managed to remove the panel without any rivets getting broken.
This is the door without the panel.
My door would "clunk" when slammed because the adhesive on the door stiffener had broken loose.
While I was in there I copied down the 5-digit key code stamped on the door lock.
mountainmanjoe (March 14th, 2024)
Old May 8th, 2024, 5:49 AM
warpday's Avatar
Well done. Also those door handles are cursed, they break if you look at them wrong.
Molot_Vepr_308
Express & G-Series Vans
February 17th, 2024 3:53 PM
metalrain
December 14th, 2023 8:39 AM
eeeskwa
February 28th, 2023 2:19 PM
ukrkoz
January 3rd, 2018 5:47 PM
84395tahoe
July 29th, 2011 3:57 PM
Quick Reply: Tracker 101: intro to door panel removal
