2003 Tracker ZR2 not cranking
I just pulled up behind the shop and shut my Tracker off. It decided that it would not turn over with the key any longer. I have checked all the connections and grounds. The battery and starter both checked good. There's no current going to the solenoid when the ignition is in the start mode. I hear a slight click behind the glove box. There is no current going through the firewall to the solenoid (black wire w/ yellow tracer). I feel like the click is the pcm... Please help!!
. *the engine starts and runs with a remote wire to the solenoid and the original wire unplugged.
>> Please help!!
This is the wiring diagram for my 2001 V6 automatic:
If I were having this problem I would unplug the connector at the transmission range switch and check continutity in both directions. That should give you some idea where the problem is.
Rhianna Brown
August 28th, 2016 12:36 PM
