Tracker 1989-2004
Platform: CAMI (Suzuki)
2003 Tracker ZR2 not cranking
Old Apr 29, 2024 | 11:32 AM
Andy B's Avatar
Default 2003 Tracker ZR2 not cranking
I just pulled up behind the shop and shut my Tracker off. It decided that it would not turn over with the key any longer. I have checked all the connections and grounds. The battery and starter both checked good. There's no current going to the solenoid when the ignition is in the start mode. I hear a slight click behind the glove box. There is no current going through the firewall to the solenoid (black wire w/ yellow tracer). I feel like the click is the pcm... Please help!!
. *the engine starts and runs with a remote wire to the solenoid and the original wire unplugged.
Old Apr 29, 2024 | 8:48 PM
L84sky's Avatar
>> Please help!!
This is the wiring diagram for my 2001 V6 automatic:
If I were having this problem I would unplug the connector at the transmission range switch and check continutity in both directions. That should give you some idea where the problem is.
Country6683
Aug 19, 2021 2:16 PM
Antonio Sc
Apr 11, 2012 11:17 AM
jrs26
Jun 22, 2011 8:37 PM
