Notices
Sponsored by: DashLynx
1992 Chev 2500 almost stalls when braking
Old June 1st, 2009, 10:57 AM
fur_fenton's Avatar
Exclamation 1992 Chev 2500 almost stalls when braking
Hi everyone, first post on the board so thanks for listening. Ive got a 1992 3/4 ton with a 350 5 speed that seems like it wants to stall whenever i put in the clutch and roll up to a stop sign. The rpms drop to about 100 and then climb back up to normal but it doesnt sound good and makes me nervous if Im in traffic. I can be driving on the highway doing 80 and if i put the clutch in and let off the gas it seems to do the same thing so Im at a loss. Ive had the TPS replaced, the IAC cleaned, new filters and gaskets in the TBI system, fuel filter changed. If anyone has any ideas Im open to all suggestions. Thanks!
Old June 1st, 2009, 1:54 PM
92Stepside's Avatar
I had the same problem on my 350 tbi automatic. when i let off the gas it would bog to about 100 rpms then recover. real annoying. I replaced the TPS and ECTS and it did nothing. It seemed to only do it once the engine got warm. brought it into a shop, they unhooked the egr. said it was faulty. now it doesnt do it anymore i dont know how they did it either. the check engone light inst even on. they said i should get a new one however.
Old June 1st, 2009, 2:27 PM
ROTM Coordinator
Mike Sigmond's Avatar
Have you checked your battery or alternator? Loose wiring as well?
Old June 1st, 2009, 2:51 PM
fur_fenton's Avatar
Thanks for the replies. I have a brand new battery and alternator and its charging fine. Im curious about the EGR so Ill have to have a look and see if I can wither disconnect it or get a new one. Thanks
Old June 1st, 2009, 9:41 PM
fur_fenton's Avatar
Well I disconnected the egr and plugged the lines and it went away! no check engine light either. will it hurt anything to run it without an egr hooked up?
Old June 1st, 2009, 9:45 PM
not really , it may run a bit stronger too, I don't think the EGR was monitored by the ECM unitl 96-97 models
Old June 2nd, 2009, 1:19 AM
ROTM Coordinator
I am glad my model didnt come with EGR, got in Texas. EGR is like a human that smokes, it just slows you down physically You need it for a smog inspection though in most states.
Old June 2nd, 2009, 10:10 AM
fur_fenton's Avatar
Thats the best news Ive heard all day. thanks for all the help!
webby00011
January 21st, 2015 7:47 PM
AgentM
December 1st, 2014 6:03 PM
lobo93065
July 28th, 2011 8:48 PM
dhertzog4349
July 8th, 2010 9:14 PM
Sevens
January 29th, 2009 10:06 AM
Quick Reply: 1992 Chev 2500 almost stalls when braking
