Notices
Sponsored by: DashLynx
1995 Chevy 1500 Vibration at 40 mph
Old March 26th, 2015, 1:29 PM
dmancello's Avatar
Post 1995 Chevy 1500 Vibration at 40 mph
My 1995 Chevy 1500 (4.3L) starts vibrating at about 40 mph and I'm running out of ideas for the cause. The vibration occurs whether I'm braking or not braking. The vibration feels to be coming from the front of the truck. I have replaced or had the following done:
-4 new tires (weighted and balanced)
-Alignment
-New tie rod ends
-New pitman arm
-New idler arm
-New wheel bearings
-New brake calipers and brake lines
I also took the truck to a local mechanic and he checked everything that has been replaced and couldn't figure it out. I suggested that maybe the ball joints could be the cause (they are original with 220,000+ miles on the truck) and after he checked them, he said that they were good. Please help...
Old March 26th, 2015, 5:05 PM
poncho62's Avatar
Did they check the "U" joints......Might feel like its coming from the front, but vibrations can be deceiving
Old March 26th, 2015, 5:36 PM
dmancello's Avatar
U joints haven't been checked. Thanks for the reply. I'll be sure and check.
Old November 26th, 2023, 11:28 PM
mals 1995 Silverado's Avatar
Default Mines been doing the same I’m going to change the o Idle Air Control Valve seal clip
-Alignment
-New tie rod ends
-New pitman arm
-New idler arm
-New wheel bearings
. Title
Old December 2nd, 2023, 10:46 AM
dpieroni3's Avatar
Not knowing the frequency of the vibration. Could it be a tire issue (road force)? Do you feel it in the steering wheel (front end) or the seat (rear) ? Is it a shimmy or a vibration? Could it be duplicated on the lift? Hope this helps isolate your concern.
Old December 2nd, 2023, 10:50 AM
dpieroni3's Avatar
Could also be drive shaft balance issue. Just a couple of thoughts.
Old December 2nd, 2023, 4:35 PM
You're replying to a 9 year old topic
Old December 2nd, 2023, 6:34 PM
dpieroni3's Avatar
I didn't see that. Guess it's time for new cheater's. Thanks
3Hands
July 26th, 2021 1:36 PM
SUPERULY
December 9th, 2015 8:38 PM
bigcar
April 29th, 2009 11:33 PM
mikesmith
August 6th, 2008 10:03 AM
amos221
January 21st, 2007 11:04 PM
Quick Reply: 1995 Chevy 1500 Vibration at 40 mph
