1998 SILVERADO FUEL PUMP GOING BAD?
Hi all, I am wondering if any of you guys ever had afuel pump go bad on your trucks around my year, and what are some of the symptoms. Mine chugs pretty good going up hill at higher speeds and when i shut it off i can hear the pump still running for up to 15 to 20 seconds. i checked running fuel pressure and it is good. Any ideas?
RE: 1998 SILVERADO FUEL PUMP GOING BAD?
Yes i have changed the filter also plugs , plug wires , cap, rotor. I am running out of things to change. Thanks for the response.
ORIGINAL: MalibuMaxxSS
fuel dont gradually go, usually they just quit and that is it....check the injectors, maybe o2 sensor, causeing it some grief..
Like I said USUALLY they dont I wouldstill clean the injectors or check them see if they are still sparying good, or could be stupid o2 sensor causing you grief but that would give you an engine light I would think
have a friend who had that going on and did'nt show engine light or code and it was the throttle position switch was bad change it solved problem
Malibumaxxss, it is possible for a fuel pump to go out gradually and a lot more common then you think. On old cars most of them did just go on new cars they seem to be going slowly. I had a 91 corsica that drove form Cedar Rapids, IA to Little Rock Ak. It ran fine the whole way shut if off ate dinner wouldn't start. Got it started the next morning with starting fluid and drove it to Shreveport LA.
Cheesehead,
I would buy a Haynes book and see what it says to check for those symptoms. It should tell you how to check all the sensors. You will need a multimeter to do that though. But take your time and you will do fine.
Cheesehead,
