Notices
Sponsored by: DashLynx
1999 chevy silverado won't start
Old August 25th, 2009, 8:27 PM
apche024's Avatar
Default 1999 chevy silverado won't start
Hi, been having problems with my 1999 chevy silverado 1500 LS. truck won't start and had already changed the key ignition cylinder, ignition switch, new battery, and other fuses for the ignition. it won't even crack or turn over....can someone please help.
Old August 25th, 2009, 8:47 PM
Professional Mechanic
MDTAHOE's Avatar
You need to check the starter. The first and easiest thing to try is have someone hold the key in the cranking position and hit starter with a hammer if it starts you need a starter. If not you need to check the large cable on the starter for battery power (hot all the time) then check to see if the little wire gets power when cranking. If both of those are present you need a starter ( unless the engine is locked up). Post back with your results and I will take you to the next step.
Old August 27th, 2009, 6:35 PM
coolcam_6's Avatar
To piggyback on that, if none of those solutions work, definitely check all of your major grounds, particularly the ground that attaches to your engine. I had that problem not with my truck but with my 3000GT. The ground to the motor had come undone and I couldnt get ANYTHING when I turned the key. It turned out to be as simple as that
Old August 28th, 2009, 7:20 AM
apche024's Avatar
I took the starter to have it checked and it passed. i also have power on my truck which is indicated on the instrument panel.
Old August 28th, 2009, 9:25 PM
lukemoore646's Avatar
if your not getting power to the solenoid terminal while the key is in start you can test the starter all you want and it is still not gonna work, if there is no power there try arcing the starter over and see if it cranks, i dont know if there have been problems with the neutral safety switches but its always an idea
Old August 29th, 2009, 4:48 PM
apche024's Avatar
I try what you're saying. right now I can do anything since I'm working a double.
3blacksilverados
January 1st, 2016 1:47 PM
Farrah Elkins
September 7th, 2015 12:11 AM
Corsairball
November 24th, 2012 12:45 AM
fire5
April 27th, 2010 6:31 PM
10gunman
February 12th, 2009 7:17 PM
Quick Reply: 1999 chevy silverado won't start
