2000 5.3 Vortec
2000 5.3 Vortec
I have a 2000 5.3 Vortec out of a 2000 Chevy Silverado, it is missing the intake and coil packs and all of the wiring. Could anyone provide a list of what is needed to put this motor into a 1986 Chevy Silverado, like maybe the list of all electronics needed and of course the intake and coilpacks.
Thanks.
Thanks.
RE: 2000 5.3 Vortec
Well, could you tell me what the big steps in this would be? I dont see any problem in fitting the electronics into the 86 or the airbox and I really just need the list of electronics the motor needs.
RE: 2000 5.3 Vortec
I do not know what all you need. I just know I was looking into putting a 5.3 in my son's 96. When I started researching it I was finding there was alot more to do than what I was thinking there was. Someone else myabe able to give you all the answers you need. I researched it on google and went through several differant posts from differant sites.
RE: 2000 5.3 Vortec
you will definatly need a brain for the operation... like the stock pcmthat goes with that motoror maybe a stand-alone engine managment system...or if you want to be ancient you can go carborated...edelbrock makes a victor jr. manifold / MSD system that will allow you to run a carborator using the crank, cam, and map sensor.but if you go that way if you have an electronic transmission than you would have to get a stand alone for the tranny... it all depends on how deep you want to go... what i would suggest is go to a junk yard and pull your computer and wiring harnesses and all your electronic needs. pretty much anything off a GM truck/suv that uses a 5.3 is compatible. with this all said do not use this as 100% fact. i have not did the swap so there will be walls that im not seeing off the top of my head.
jaxontipedeau
Silverado & Fullsize Pick-ups
February 6th, 2011 11:48 AM
