Notices
Sponsored by: DashLynx
92 chevy wont start
Old May 17th, 2010, 3:43 PM
Hogfan's Avatar
Default 92 chevy wont start
I have a 92 chevy Z71 full size pickup. Has 350 and the truck will not start, no fuel at the throttlebody. I can hear the fuel pump run when I turn the key over for a couple seconds. When its primed it just runs until the fuel burns then dies again. Thanks for any help..
Old May 17th, 2010, 5:44 PM
maxxman04's Avatar
clogged fuel filter, blown injector fuse.
Old May 17th, 2010, 6:46 PM
Hogfan's Avatar
fuel pump relay is good. injector fuse..where is the injector fuse on this truck with a throttlebody?? Thanks
Old May 17th, 2010, 9:37 PM
maxxman04's Avatar
relay good, but how is the filter? fuse is in fuse panel, should be marked "INJ" if i remember right.
Old May 18th, 2010, 7:03 AM
Hogfan's Avatar
filter is good, removed it and had gas run out of both lines going to tank and to engine..and gas looked very good.
Old May 18th, 2010, 8:18 PM
Hogfan's Avatar
ok, i was listening again when i turn the key over today and i hear the relay click under the hood and here a click at the tank but no buzzing sound for a couple seconds....think I have a bad fuel pump after all
Old May 19th, 2010, 9:59 AM
cooter26's Avatar
Rent a Fuel pressure gauge and test it at the fuel rail. Your truck will not shoot fuel through the TBI if you dont have spark so check that first.
Old May 20th, 2010, 7:00 AM
Hogfan's Avatar
when its primed with gas it will run for a few seconds, so would that not tell me that I have spark??
Old May 20th, 2010, 7:08 AM
maxxman04's Avatar
yes, there is spark. does sound like pump is shot. not hard to replace. make sure you get a new wiring kit when you buy pump. parts stores should have these in stock. the old wires tend to burn/melt just a little. splice new wires in place of old, good to go.
Old May 20th, 2010, 12:18 PM
Hogfan's Avatar
thanks, I will get the wiring kit
Quick Reply: 92 chevy wont start
