Notices
Sponsored by: DashLynx
AC problems
Old July 28th, 2011, 4:48 PM
  #11
ah21283's Avatar
could it be the switch board? where you turn the ac from low to high? absolutely nothing happens while turning the ****
Old July 28th, 2011, 4:51 PM
  #12
kevinkpk's Avatar
Until you check the motor, you will be chaseing it. If the motor is good, that eleminates most of the problem
Old July 28th, 2011, 5:16 PM
  #13
ah21283's Avatar
ill check it out
Old July 28th, 2011, 5:59 PM
  #14
ah21283's Avatar
i literaly just pulled the blower motor out, and stuck it back in and now it works on 3 and 2 but not 1,4,or 5? i guess its better than no ac in texas!!
Old July 28th, 2011, 6:20 PM
  #15
kevinkpk's Avatar
Yea, i am in Oklahoma, real hot. I'd suggest it is the switch.
Old July 29th, 2011, 9:27 AM
  #16
RacerX's Avatar
Great then it is most likely the resistor block. It is in the same place as the motor is.
Old July 29th, 2011, 9:54 AM
  #17
kevinkpk's Avatar
It might be, I'd suggest check the switch also. BTW what model is your 98?
Old July 29th, 2011, 10:36 AM
  #18
RacerX's Avatar
I dont think it is the switch. If it was the switch it wouldnt work at any speed. You get function at intermediary speeds, sounds like resistor block.
Old July 29th, 2011, 12:56 PM
  #19
GM Fixer's Avatar
yup...the resister block is it, also check fuse in under hood green 40 amp for the blower.
Mom2ThreeACG
Traverse
March 12th, 2018 6:20 PM
wayne77&Trish
Sonic (Aveo)
June 9th, 2016 12:54 AM
mwehrste
December 29th, 2014 11:19 AM
GrayHeadedMule
July 9th, 2013 10:16 PM
Big C
September 2nd, 2011 4:39 PM
Quick Reply: AC problems
