Braking shake
Braking shake
Hello. I have an 06 Silverado 4x4. Recently replaced rear drake drums and front rotors along with all brake pads and shoes.
I now have a bad vibration when braking. No pulsation in the peddle but the truck shake in an up and down motion.
Any help would be very useful.
thank you
thank you
If the pedal doesn't pulse, then it won't be rotors.
I would check the tires for irregularities and get the wheels balanced.
Go back and give everything a once over.
rear brakes will transfer thru the floor of the vehicle and pedal.
if you bought the cheap line ac delco advantage drums...they will be 0.010" out of round right out of the box. This happened to me repeatedly with these drums....now I put them on a lathe to check them before installation.
take it back to the dealer and let them correct it.
