Notices
Broken u-joint strap bolt......
Old June 19th, 2010, 11:39 PM
Bill's Dad's Avatar
Default Broken u-joint strap bolt......
1 bolt snapped inside rear yoke at pinion and of course the easyout snapped inside that I don't see how removal is possible at this point? Was thinking another yoke, in fact we couldn't get it to budge off the pinion. parts guy says to use a slide hammer which we rented 1 from him. Would r&r or all the poundin on yoke mess up any pinion tolerances/setup? Then I was thinking may be to have the 1 side of strap tack welded to yoke-quick/easy but pain if and when that joint fails again. what do you think? TIA!
Old June 20th, 2010, 9:34 AM
gotstylez's Avatar
i'v learned to NEVER use a easy out... i snapped a bolt taking off the thermostat housing in a 88 trans am..used a easy out and snapped it in there too lol.. HORRIBLE!.. oh and you cant drill them out.. i'v tried for 3 days straight.. i would tack it.. but thats just me.. maybe somebody else can answer and you can actually get the bolt out
Old June 20th, 2010, 9:49 AM
Professional Mechanic
MDTAHOE's Avatar
You need to use a 2 jaw puller to remove the yoke.
http://www.amazon.com/OTC-1024-Rever.../dp/B0002SRFLM
Old June 20th, 2010, 8:19 PM
eisenhauer01's Avatar
md tahoe is correct. when you get yoke off you can either replace it, or take it to a machine shop and get them to carbide it out with an endmill and pick the threads. It will be good as new. I work at one, so I am not just telling you bs.
Old June 22nd, 2010, 5:21 PM
Knucklehead's Avatar
If you have a welder, then why not weld a nut onto whatever you have left. The heat will help it release.
Lynns
October 22nd, 2018 5:05 AM
NomadJeep
Express & G-Series Vans
February 24th, 2015 6:55 PM
Johnrockys
October 6th, 2013 3:37 AM
Avenged7x
October 5th, 2011 11:15 PM
scottmac
September 28th, 2008 12:22 PM
Quick Reply: Broken u-joint strap bolt......
