Notices
Sponsored by: DashLynx
Coolant in the oil
Old November 1st, 2008, 11:13 PM
Coppertop71's Avatar
Default Coolant in the oil
I have been loosing coolant for awhile and now when changing the oil I find that by pressurizing the coolant tank coolant dribble out of the drain hole. It looks like the intake on a 01 5.3L doesn't have coolant flowing through it and there appears there is a cover plate that covers the push rod oil galley so it look like the intake gasket is not the problem area. So my best case scenario points to the head gasket as the cause but does anyone know if this is common problem on the 5.3L or is there is any other item I overlooked?
Old November 2nd, 2008, 9:11 PM
cdusthockey's Avatar
Default RE: Coolant in the oil
check out the heads, these have been prone to cracking heads, i have known too many that have had the same simptoms as you have.
Old November 3rd, 2008, 9:06 PM
Thanks for the info, I will probably yank them off this month sometime are there any specials tools required?
dlaroche
October 29th, 2014 7:17 PM
Eric Sherden
September 24th, 2013 1:21 PM
grndslm
December 18th, 2012 2:38 AM
blkclipse
May 24th, 2008 8:15 PM
larry_chip
April 24th, 2007 11:46 AM
Quick Reply: Coolant in the oil
