Old Jul 27, 2015, 12:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Crank Position Sensor??
Old Sep 6, 2010 | 2:26 PM
bigq11's Avatar
Default Crank Position Sensor??
2008 Silverado 1500, 2 wheel drive, automatic tranny, 5.3 engine, not flex fuel.
While driving along yesterday and using the cruise, I felt a slight jerk and noticed the check engine light had come on and the tach had quit working. The cruise still worked, but the truck seem to lose some power and ran quite rough, especially when it changed to the 4 cyl mode.
When I had to come to a stop, as I pulled away it shifted very hard and did so the rest of the way home.
When I got home, I had a local parts store read the code. It returned a "bad crank position sensor". He cleared the code, but it immediately came back on. Today, I had to go on a short trip. Althought the check engine light was still on, the truck started fine, ran fine, shifted fine, and the tach worked. I went back to parts store and had him clear the code again. This time it did not come back on and continues to perform as it should.
Would the bad sensor cause the tack to stop working, running rough, and shifting hard? And is this known to be an intermittent problem with the crank sensor?
Tom
Old Sep 8, 2010 | 8:41 PM
tinbender59's Avatar
YES!! YES!! YES!!! I am having the same issue with my GP, only thing is it likes to act up 50 miles from home. finally got it traced to the crank sensor fixing it tommorow
Old Sep 9, 2010 | 7:07 AM
bigq11's Avatar
Default Thanks
Thanks for the info. Got mine replaced yesterday.
Old Sep 9, 2010 | 11:32 PM
did it fix it???
Old Sep 10, 2010 | 5:35 AM
bigq11's Avatar
Yes. Just hope it doesn't happen again.
Old Sep 10, 2010 | 11:07 AM
ditto
Old May 10, 2011 | 10:43 PM
08silveradoonrims's Avatar
did u use OEM or aftermarket?
Old May 11, 2011 | 12:47 PM
Did u use OEM or aftermarket?
Old May 11, 2011 | 12:53 PM
i went to a top end parts house, same quality as Manufacture is. the corner parts houses sell second, and third quality parts, OK in a pinch. if you don't believe me look at the AC spark plugs, top quality have blue bands around them and the cheapy's just have the number.
my personal method is OEM quality on any thing that could strand me on the side of the road. electronic parts, battery, fuel related parts.... you get the hint, I have bought "new" electronics that ran worse than the one it replaced, from the corner parts house's I learned my lesson a long time ago.
icemanthe1
Sep 25, 2012 5:18 PM
topwhop1977
Sep 12, 2012 11:52 PM
Vince
Astro
Oct 1, 2010 6:07 AM
bbish0p
Feb 8, 2010 2:17 AM
kidm28
Oct 20, 2006 6:18 AM
